I've only been using it for about a week and its an awesome tool but unfortunately it lacks any kind of info regarding rejections.
I've found the graphs for the MAilgraph stats: GUI => TOOLS/LINKS => Mailgraphs Stats and saw the huge number of rejected emails. After a quick look at the logs I see it uses spamhaus to reject clients, what else does it use?
and talking about the mailgraphs stats, seeing that I am only using EFA to filter incoming emails, how come its says:
SENT: 56
RECEIVED: 95
I would have expected the sent number to be higher than received as I think it also sends me warnings and daily reports and emails to recipients telling them their email was filtered... so how come sent is lower than received?
						What criteria does EFA use for rejecting incoming email connections?
Re: What criteria does EFA use for rejecting incoming email connections?
Look in /etc/MailScanner/MailScanner.conf and /etc/postfix/main.cf for RBLs in use.
I think there is an active bug/PR for this over at the MailWatch project
thanks. I noticed we are using postfix 3.0.4 so I exchanged  reject_invalid_hostname with reject_invalid_helo_hostname according to: http://www.postfix.org/postconf.5.html# ... o_hostname
I also noticed:
smtpd_recipient_restrictions = check_policy_service inet:127.0.0.1:2501
and I cannot see anything running on that port
						I also noticed:
That should be the SQLGrey perl daemon.
[user@efa postfix]$ netstat -plutn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address               Foreign Address             State       PID/Program name
tcp        0      0 127.0.0.1:2501              0.0.0.0:*                   LISTEN      2238/perl
[user@efa postfix]$ ps -ef |grep 2238
sqlgrey   2238     1  0 Apr11 ?        00:00:58 /usr/bin/perl -w /usr/sbin/sqlgrey -d
root      5363  4693  0 23:58 pts/0    00:00:00 grep 2238Re: What criteria does EFA use for rejecting incoming email connections?
ah, I see, looks all god then, thanks!
