SSL issues after upgrading to 3.0.0.9
tjg88
After I upgraded to 3.0.0.9, the upgrade seems to have reverted my system back to a self signed certificate. Is this a known issue?
Re: SSL issues after upgrading to 3.0.0.9
no bug, feature.
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
"HTTPS Enabled by Default"
no bug, feature.
I note that the release notes are wrong.....
if says that the cert/key are in:
but they are actually in:
/etc/pki/certs/localhost.crt
/etc/pki/private/localhost.keyCode: Select all
/etc/pki/tls/certs/localhost.crt
/etc/pki/tls/private/localhost.key
