Issue #148 Enhancement - Allow message view from quarantine reports directly
Posted: 22 Mar 2016 19:25
by peter.munnelly
Can you let me know what this should do.
From what I can see in 3.0.0.9 nothing in the quarantine report has changed from the last version.
Should I be able to view the message without having to login to the quarantine area?
Re: Issue #148 Enhancement - Allow message view from quarantine reports directly
Posted: 22 Mar 2016 19:28
Sure it has, after you log in it takes you to the message.
There is NO way to do this without authenticating. That would result in a big gaping hole in your appliance!
Posted: 23 Mar 2016 17:56
by peter.munnelly
Ok thanks.
With regards to the quarantine report, I have it set to only show spam within the last day, but this still shows 2 days worth of spam emails.
Is there a way to set it so that it only shows the current day?
Posted: 30 Mar 2016 10:15
by akl
Hi Shawn,
the Viewer seems to be not working for me.
Here is a screenshot of what I see by clicking on "view"
Can you help?
Thx
akl
