Issue #148 Enhancement - Allow message view from quarantine reports directly
peter.munnelly
Post by peter.munnelly »
Can you let me know what this should do.
From what I can see in 3.0.0.9 nothing in the quarantine report has changed from the last version.
Should I be able to view the message without having to login to the quarantine area?
Re: Issue #148 Enhancement - Allow message view from quarantine reports directly
Sure it has, after you log in it takes you to the message.
There is NO way to do this without authenticating. That would result in a big gaping hole in your appliance!
peter.munnelly
Ok thanks.
With regards to the quarantine report, I have it set to only show spam within the last day, but this still shows 2 days worth of spam emails.
Is there a way to set it so that it only shows the current day?
akl
Post by akl »
Hi Shawn,
the Viewer seems to be not working for me.
Here is a screenshot of what I see by clicking on "view"
Can you help?
Thx
akl
