Update to Version 3.0.0.9 FAILED
Posted: 20 Mar 2016 13:25
Transaction Summary
Install 33 Package(s)
Total download size: 5.1 M
Installed size: 18 M
Downloading Packages:
Total 1.6 MB/s | 5.1 MB 00:03
Running rpm_check_debug
Running Transaction Test
Transaction Check Error:
file /usr/share/man/man3/XML::SAX::Base.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
file /usr/share/man/man3/XML::SAX::Exception.3pm.gz from install of perl-XML-SAX-0.96-7.el6.noarch conflicts with file from package perl-XML-SAX-Base-1.04-1.el6.rf.noarch
Error Summary
Update to Version 3.0.0.9 FAILED. Updates cancelled.
All done
Thank you for using E.F.A.
Error Summary
All done
