Error updating ClamAV
Posted: 11 Feb 2016 07:31
Since a few weeks i'm getting errors while trying to update ClamAV via webmin.
Allready tried to update it directly using yum in the console, error stayed the same. The only Forum entry i found (viewtopic.php?f=8&t=1085) was of no use to me, as the most recent version of EFA is allready installed.Loaded plugins: fastestmirror, security
Setting up Install Process
* base: mirror.imt-systems.com
* epel: mirror.fraunhofer.de
* extras: ftp.fau.de
* rpmforge: mirrors.neterra.net
* updates: centos.mirrors.as250.net
Resolving Dependencies
--> Running transaction check
---> Package clamav.x86_64 0:0.98.7-1.el6 will be updated
--> Processing Dependency: libclamav.so.6()(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6()(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PRIVATE)(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: clamd-0.98.7-1.el6.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
--> Processing Dependency: clamav = 0.98.7-1.el6 for package: clamd-0.98.7-1.el6.x86_64
---> Package clamav.x86_64 0:0.99-3.el6 will be an update
--> Processing Dependency: clamav-db = 0.99-3.el6 for package: clamav-0.99-3.el6.x86_64
---> Package clamav-db.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamav-db.x86_64 0:0.99-3.el6 will be an update
---> Package clamd.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamd.x86_64 0:0.99-3.el6 will be an update
Error: Package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64 (@rpmforge)
Requires: libclamav.so.6()(64bit)
Removing: clamav-0.98.7-1.el6.x86_64 (@epel)
Updated By: clamav-0.99-3.el6.x86_64 (epel)
Not found
Available: clamav-0.96.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.96.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.2-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.6-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.7-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.4-1.el6.rf.x86_64 (rpmforge)
Requires: libclamav.so.6(CLAMAV_PUBLIC)(64bit)
Not found
.. Installation fehlgeschlagen!
Update jetzt clamav-db ..
Installiere Paket(e) mit Befehl /usr/bin/yum -y install clamav-db ..
--> Processing Dependency: clamav-db = 0.98.7-1.el6 for package: clamav-0.98.7-1.el6.x86_64
Not found
Not found
Update jetzt clamd ..
Installiere Paket(e) mit Befehl /usr/bin/yum -y install clamd ..
--> Processing Dependency: clamav = 0.99-3.el6 for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PUBLIC)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PRIVATE)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7()(64bit) for package: clamd-0.99-3.el6.x86_64
Not found
Not found
Does anybody has an idea? Thanks![EFA] Good you are root
[EFA] You are already running the latest version, no update needed
