Setting up Install Process
* base: mirror.imt-systems.com
* epel: mirror.fraunhofer.de
* extras: ftp.fau.de
* rpmforge: mirrors.neterra.net
* updates: centos.mirrors.as250.net
Resolving Dependencies
--> Running transaction check
---> Package clamd.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamd.x86_64 0:0.99-3.el6 will be an update
--> Processing Dependency: clamav = 0.99-3.el6 for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PUBLIC)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7(CLAMAV_PRIVATE)(64bit) for package: clamd-0.99-3.el6.x86_64
--> Processing Dependency: libclamav.so.7()(64bit) for package: clamd-0.99-3.el6.x86_64
---> Package clamav.x86_64 0:0.98.7-1.el6 will be updated
--> Processing Dependency: libclamav.so.6()(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
--> Processing Dependency: libclamav.so.6(CLAMAV_PUBLIC)(64bit) for package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64
---> Package clamav.x86_64 0:0.99-3.el6 will be an update
--> Processing Dependency: clamav-db = 0.99-3.el6 for package: clamav-0.99-3.el6.x86_64
---> Package clamav-db.x86_64 0:0.98.7-1.el6 will be updated
---> Package clamav-db.x86_64 0:0.99-3.el6 will be an update
Error: Package: perl-Mail-ClamAV-0.29-1.el6.rf.x86_64 (@rpmforge)
Requires: libclamav.so.6()(64bit)
Removing: clamav-0.98.7-1.el6.x86_64 (@epel)
Updated By: clamav-0.99-3.el6.x86_64 (epel)
Not found
Available: clamav-0.96.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.96.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.2-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.4-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.5-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.6-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.97.7-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98-2.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.1-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.3-1.el6.rf.x86_64 (rpmforge)
Available: clamav-0.98.4-1.el6.rf.x86_64 (rpmforge)
Requires: libclamav.so.6(CLAMAV_PUBLIC)(64bit)
Not found
Allready tried to update it directly using yum in the console, error stayed the same. The only Forum entry i found (viewtopic.php?f=8&t=1085) was of no use to me, as the most recent version of EFA is allready installed.
[EFA] Good you are root
[EFA] You are already running the latest version, no update needed
