ClamAV update
VMguru
ClamAV update
Post by VMguru »
I received these in an email from our appliance:
An update to clamav from 0.98.7-1.el6 to 0.99-3.el6 is needed.
However, this update could not be installed! Try the update manually using the Package Updates module.
An update to clamav-db from 0.98.7-1.el6 to 0.99-3.el6 is needed.
An update to clamd from 0.98.7-1.el6 to 0.99-3.el6 is needed.
Can anyone help explain to me (a Windows guy) how to proceed?
Thank you.
Re: ClamAV update
Windows guy eh?
First you launch Visual Studio, then you create a new project....
hehe, jk :lol:
This is an ongoing and known issue.
viewtopic.php?f=13&p=4893
The fix is a field test at the moment, until I can confirm it doesn't cause other issues. :dance:
In your case you would skip the EFA-Update (last line) and try to proceed with updating ClamAV after ripping out the old perl module rpm and dropping in the new one.
Basically, perl-Mail-ClamAV rpm from the old repoforge is throwing fits about libclamav.so.6 not being around anymore. I have built a new rpm to test that references libclamav.so.7 instead.
murphyk
Re: ClamAV update
Post by murphyk »
The fix is confirmed to be working. All is good.
VMguru
Re: ClamAV update
Post by VMguru »
Yup Windows guy. :dance:
Anywho, was wondering if you happened to try your rpm package yet?
If so is it available to try?
In other words do I download clamav-0.99-3.el6.x86_64.rpm from https://dl.fedoraproject.org/pub/epel/6 ... lamav.html
and execute:
sudo rpm -e --nodeps perl-Mail-ClamAV
sudo rpm -ivh --nodeps clamav-0.99-3.el6.x86_64.rpm
Or should I follow the exact steps in you referenced in : viewtopic.php?f=13&p=4893
Skipping the last line. So I literally execute:
wget http://dl.efa-project.org/rpm/CentOS/6/ ... x86_64.rpm
sudo rpm -ivh --nodeps perl-Mail-ClamAV-0.29-2.efa.el6.x86_64.rpm
Let me know, thank you.
Re: ClamAV update
VMguru wrote:Yup Windows guy. :dance:
Follow these steps and you should be good. Then you can run yum update clamav.
VMguru
Re: ClamAV update
Post by VMguru »
That worked perfectly!
Thank you shawniverson. :clap:
