I followed the directions to enable LDAP integration. It works great. No problems there. The issue I am having is that the admin username I created originally in EFA is the same as the admin username in our active directory and when I log into the mail watch interface with that account it treats it like a regular user account and I've lost any admin options.
I need to figure out how to set up quarantine report emails for users, and how to fine tune them to send multiple times a day and just display the quarantined messages since the last quarantine report.
I also need to figure out how to turn off the "{Spam Not Delivered}" email notifications.
I assume these settings are in the mail watch web interface which I can no longer get admin access to. Any thoughts? Thank you!
						LDAP Logins
Re: LDAP Logins
Look in /etc/MailScanner/MailScanner.conf. You'll need to be a root user to edit this file.james27_84 wrote:I also need to figure out how to turn off the "{Spam Not Delivered}" email notifications.
Look for the following settings:
Spam Actions =
High Scoring Spam Actions =
Non Spam Actions =For reference, my settings are:
Spam Actions              = store deliver header "X-Spam-Status:Yes"
High Scoring Spam Actions = store header "X-Spam-Status:Yes"
Non Spam Actions          = store deliver header "X-Spam-Status:No"-
				james27_84
Re: LDAP Logins
Thank you for the reply. I started down the path you showed me, and actually did find the configurations you spoke of, but took a step back and opened the "Spam Settings" section in EFA-Config. Duh. That's where it was. Last issue then, when I log in as my users quarantine report is unchecked. Is there a setting somewhere that will enable the quarantine report for everyone?
						Re: LDAP Logins
Good question.
I have no idea. Time to figure it out, unless some kind soul gives me a pointer.
Re: LDAP Logins
Yeah, I recall this. Not a setting per-se, but a way to force it on. The answer is hidden deep in the forums somewhere (its been a while)...james27_84 wrote:Last issue then, when I log in as my users quarantine report is unchecked. Is there a setting somewhere that will enable the quarantine report for everyone?
viewtopic.php?f=5&t=868
Re: LDAP Logins
Useful to know, linked to the wiki
