Polish language
Posted: 31 Aug 2015 07:41
by maciekh
Hello
When i view recent messages spam i cant' see polish letters:
for example: "ciÄ
gÅoÅci" should be: "ciągłości"
Is there any cure for this?
Best regards
Maciej
Re: Polish language
Posted: 31 Aug 2015 14:17
What version of EFA are you running?
Re: Polish language
Posted: 01 Sep 2015 07:32
by DaN
@pdwalker
as far as i know, the last versions from mailwatch in EFA had this UTF8 problem.
@moderator
please move to "bugs"
Re: Polish language
Posted: 01 Sep 2015 09:08
The latest version partially fixes this problem, which is why I asked what version he's running. See below.
Notice the u in Peru in the low spam message, and the Chinese characters in the other messages.
In 3.0.0.7, all the foreign language characters would have been gibberish.
In 3.0.0.8, the characters appear properly in the "message list" and "recent messages" screens but
incorrectly elsewhere
Re: Polish language
Posted: 01 Sep 2015 11:18
by maciekh
i'm using 3.0.0.8, installed few days ago.
Message listing and Recent messages shows the same issue.
Best regards
Maciej
Re: Polish language
Posted: 01 Sep 2015 11:48
by DaN
3.0.0.8
German umlauts (ö, ü) in "recent messages":
- german umlauts.png (9.13 KiB) Viewed 16314 times
same problem in "Reports" > "Message Listing"
Re: Polish language
Posted: 01 Sep 2015 15:45
DaN,
sent you a pm on this matter.
Re: Polish language
Posted: 02 Sep 2015 06:58
by DaN
answered
- umlaute.PNG (1.31 KiB) Viewed 16303 times
Re: Polish language
Posted: 02 Sep 2015 07:47
This is what I got:
so it appears that my system is showing it correctly.
I'm using the EFA build from scratch version running on Centos 6.x.
My client machine is Mac OSX 10.10 running the latest version of Chrome.
So my system must have a difference. So did I change anything... *thinks*
Oh! I remember!
sudo yum install php-mbstring
sudo service httpd restart
This fixes the display problem in the message listing.
It doesn't fix the problem everywhere, but at least the message listing looks ok once php-mbstring is installed.
Check your system (phpinfo(); then search the page for mbstring)
Re: Polish language
Posted: 02 Sep 2015 08:25
by maciekh
"CODE: SELECT ALL
sudo service httpd restart"
helped ! THANK YOU
Re: Polish language
Posted: 02 Sep 2015 08:30
by DaN
Installation of php-mbstring fixed the problem. Thanks.
@darky
Would't it be nice, if "php-mbstring" is included in the ova?
Re: Polish language
Posted: 02 Sep 2015 15:04
by darky83
Added this to the bug we already have open to fix the formatting issues.
https://github.com/E-F-A/v3/issues/199
We will add it to the next version by default.
