Polish language
maciekh
Polish language
Post by maciekh »
Hello
When i view recent messages spam i cant' see polish letters:
for example: "ciągłości" should be: "ciągłości"
Is there any cure for this?
Best regards
Maciej
Re: Polish language
What version of EFA are you running?
DaN
Re: Polish language
Post by DaN »
@pdwalker
as far as i know, the last versions from mailwatch in EFA had this UTF8 problem.
@moderator
please move to "bugs"
Re: Polish language
The latest version partially fixes this problem, which is why I asked what version he's running. See below.
Notice the u in Peru in the low spam message, and the Chinese characters in the other messages.
In 3.0.0.7, all the foreign language characters would have been gibberish.
In 3.0.0.8, the characters appear properly in the "message list" and "recent messages" screens but incorrectly elsewhere
maciekh
Re: Polish language
Post by maciekh »
i'm using 3.0.0.8, installed few days ago.
Message listing and Recent messages shows the same issue.
Best regards
Maciej
DaN
Re: Polish language
Post by DaN »
3.0.0.8
German umlauts (ö, ü) in "recent messages":
german umlauts.png (9.13 KiB) Viewed 16306 times
same problem in "Reports" > "Message Listing"
Re: Polish language
DaN,
sent you a pm on this matter.
DaN
Re: Polish language
Post by DaN »
answered
Re: Polish language
This is what I got:
so it appears that my system is showing it correctly.
I'm using the EFA build from scratch version running on Centos 6.x.
My client machine is Mac OSX 10.10 running the latest version of Chrome.
So my system must have a difference. So did I change anything... *thinks*
Oh! I remember!
sudo yum install php-mbstring
sudo service httpd restart
This fixes the display problem in the message listing.
It doesn't fix the problem everywhere, but at least the message listing looks ok once php-mbstring is installed.
Check your system (phpinfo(); then search the page for mbstring)
maciekh
Re: Polish language
Post by maciekh »
"CODE: SELECT ALL
sudo service httpd restart"
helped ! THANK YOU :)
DaN
Re: Polish language
Post by DaN »
Installation of php-mbstring fixed the problem. Thanks.
@darky
Would't it be nice, if "php-mbstring" is included in the ova?
darky83
Site Admin
Re: Polish language
Post by darky83 »
Added this to the bug we already have open to fix the formatting issues.
https://github.com/E-F-A/v3/issues/199
We will add it to the next version by default.
