Send a message to user to let them know email stopped
Posted: 11 Aug 2015 09:44
by mikemachin
Is it possible to set the system to send an email to our internal users to let them know an email they are sending out has been blocked?
Or create a quarantine report to show outgoing as well as incoming?
Re: Send a message to user to let them know email stopped
Posted: 11 Aug 2015 20:46
Are you wanting to filter your mail outbound?
I typically whitelist my domain/email server so that they don't get blocked.
Posted: 12 Aug 2015 08:15
by mikemachin
I do have the domain whitelisted however this one is a double extension so marked as bad content. The sender has asked if there is any way of notifying them if this happens
Posted: 12 Aug 2015 08:54
by DaN
If it's just the double filename extension problem:
viewtopic.php?f=15&t=1179
