Is it possible to set the system to send an email to our internal users to let them know an email they are sending out has been blocked?
Or create a quarantine report to show outgoing as well as incoming?
Send a message to user to let them know email stopped
Re: Send a message to user to let them know email stopped
Are you wanting to filter your mail outbound?
I typically whitelist my domain/email server so that they don't get blocked.
I do have the domain whitelisted however this one is a double extension so marked as bad content. The sender has asked if there is any way of notifying them if this happens
If it's just the double filename extension problem:
viewtopic.php?f=15&t=1179
