Can't access MailScanner GUI after upgrade to 3.0.0.8
I just upgraded to 3.0.0.8, and I can't access the Mailscanner GUI. The error I receive is: Could not search
Re: Can't access MailScanner GUI after upgrade to 3.0.0.8
https://raw.githubusercontent.com/E-F-A ... LEASENOTES
2) Error, "could not search" when logging into MailWatch after
updating to 3.0.0.8
This occurs when Active Directory integration is enabled.
Check /var/www/html/mailscanner/conf.php
Change the following line to 'mail' from 'proxyaddresses', if needed...
define('LDAP_EMAIL_FIELD', 'proxyaddresses');
Add the following lines back to /var/www/html/mailscanner/functions.php
In function ldap_authenticate (near line 2280), immediately before
$ds = ldap_connect...
ldap_set_option($ds, LDAP_OPT_REFERRALS, 0);
ldap_set_option($ds, LDAP_OPT_PROTOCOL_VERSION, 3);
updating to 3.0.0.8
