The following issues have been fixed in 3.0.0.8:
Issue #40 Enhancement - Extend MailWatch to hide high spam from regular users
Issue #45 Enhancement - Add ScamNailer ClamAV ruleset (superceded by issue #172)
Issue #49 Enhancement - Add max spam check size to EFA-Configure
Issue #72 Enhancement - EFA MSRE Support
Issue #132 Enhancement - Increase sa-learn and spamassassin max message size limits
Issue #150 Bug - Replace dnsmasq with unbound (URIBL_BLOCKED using dnsmasq)
Issue #157 Bug - Razor failing after registration of service
Issue #156 Bug - GeoIP Bug Fix
Issue #158 Enhancement - Sort transport domain list in EFA-Configure
Issue #161 Enhancement - Increase MailScanner thread limit in EFA-Configure
Issue #164 Enhancement - Add MailWatch Password Reset to EFA-Configure
Issue #166 Bug - MailWatch cron job not executing contents
Issue #167 Enhancement - Change perms on /etc/postfix/sasl_passwd to 600
Issue #168 Enhancement - Start regular updates on RegistrarBoundaries.pm
Issue #169 Enhancement - Clean up clamav-unoffical-sigs script (superceded by issue #170)
Issue #170 Enhancement - Add support to MalwarePatrol to EFA-Configure
Issue #171 Bug - Update clamav -- fix any clamav discrepancies
Issue #172 Enhancement - Review sanesecurity signatures for inclusion in EFA
Issue #173 Enhancement - Securiteinfo.com support removed from unofficial-sigs
Issue #175 Enhancement - Set keyboard layout at beginning of EFA-Init
Issue #177 Enhancement - Correct EFA to new clamav paths using EPEL
Issue #178 Enhancement - EFA MailWatch Unicode Support
Issue #186 Bug - Unbound full recursion support
Issue #188 Bug - Logjam Vulnerability
EFA-Update enhanced fault tolerance
EPEL Repository is now enabled
Add 4GB Swap partition to new builds.
3) If the update fails for any reason, immediately roll back to snapshot
sudo /usr/local/sbin/EFA-Update -check
continue the update process to 3.0.0.8.
if present.
