preferred setups to EFA
Posted: 09 Apr 2015 11:09
by menny
hi,
I know that EFA good to go right after initial setup,
but are there any preferred actions\setups\modifications to it that will make it even better?
Re: preferred setups to EFA
Posted: 09 Apr 2015 13:01
by DaN
hi
you know
https://efa-project.org/wiki/HowTos?
How-to check E.F.A.-Version (with a monitoring tool)
viewtopic.php?f=14&t=985
Update Spammassassin Rule Descriptions
viewtopic.php?f=14&t=568&p=3108&hilit=U ... ions#p3108
Update GeoIP Database
In Mailwatch under tools
Add trusted Domains (with many different adresses) to
Greylist
Opt-out domains (recipients for whom messages are never greylisted)
Signatures
You can disable signatures
viewtopic.php?f=14&t=684&p=1871&hilit=d ... ture#p1871
edit EFA signature files
viewtopic.php?f=14&t=895
Blocking Domains (blacklist)
Any easy way to block WeTransfer ?
viewtopic.php?f=14&t=865
wiki
https://efa-project.org/w/index.php?tit ... edirect=no
Help your SpamAssassin to learn
- SA Learn.JPG (16.3 KiB) Viewed 20477 times
Posted: 09 Apr 2015 21:04
by menny
much appreciated.
