preferred setups to EFA
menny
Post by menny »
hi,
I know that EFA good to go right after initial setup,
but are there any preferred actions\setups\modifications to it that will make it even better?
DaN
Re: preferred setups to EFA
Post by DaN »
hi
you know
https://efa-project.org/wiki/HowTos?
How-to check E.F.A.-Version (with a monitoring tool)
viewtopic.php?f=14&t=985
Update Spammassassin Rule Descriptions
viewtopic.php?f=14&t=568&p=3108&hilit=U ... ions#p3108
Update GeoIP Database
In Mailwatch under tools
Add trusted Domains (with many different adresses) to
Greylist
Opt-out domains (recipients for whom messages are never greylisted)
Signatures
You can disable signatures viewtopic.php?f=14&t=684&p=1871&hilit=d ... ture#p1871
edit EFA signature files viewtopic.php?f=14&t=895
Blocking Domains (blacklist)
Any easy way to block WeTransfer ? viewtopic.php?f=14&t=865
wiki https://efa-project.org/w/index.php?tit ... edirect=no
Help your SpamAssassin to learn
SA Learn.JPG (16.3 KiB) Viewed 20478 times
menny
Post by menny »
much appreciated.
