Web interface username & password
Posted: 31 Mar 2015 10:08
by alkarakiomar
Dear All
Kindly note that i'm a new here and this is the first time that i'm using Efa, i configured the VM, and i have the root pssword, but when i try to use the web interface i cannot login.
could you please guide me that how i can login to it.
Thank you
Re: Web interface username & password
Posted: 31 Mar 2015 13:48
by DaN
Posted: 01 Apr 2015 09:19
by alkarakiomar
I follow the below link and i use the below command
/usr/bin/mysql -u mailwatch -p XXXXXXXXX mailscanner -e "UPDATE users SET password = md5('XXXXXXX') WHERE user=admin'"
but still i cannot access the web interface.
Waiting your feedback
Posted: 01 Apr 2015 10:54
by DaN
I'm not sure, but it seems that there is no space in "-p<MailwatchPWD>".
Do you consider this?
user=admin'
should be
user='admin'"
/usr/bin/mysql -u mailwatch -pMailwatchPWD mailscanner -e "UPDATE users SET password = md5('YourNewUserPassword') WHERE user='YourUsername'"
Posted: 01 Apr 2015 13:36
Posted: 05 Apr 2015 09:56
by alkarakiomar
Thank you for you reply but still not working
I use the below command exactly , and I add ' before admin
/usr/bin/mysql -u mailwatch -p XXXXXXXXX mailscanner -e "UPDATE users SET password = md5('XXXXXXX') WHERE user='admin'"
but when i press Enter it will give me" the attached file "
and when I re-login to Web interface it's fail login.
Thank you for your support
Posted: 07 Apr 2015 07:40
by DaN
You still have a blank space between -p and password!?
Posted: 07 Apr 2015 07:57
by darky83
Please keep in mind that the username is the user you gave during the setup.
You can list your users with the command:
/usr/bin/mysql -u mailwatch -p`cat /etc/EFA-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "select * from users"
To reset use the mentioned reset command.
/usr/bin/mysql -u mailwatch -p`cat /etc/EFA-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "UPDATE users SET password = md5('YOURPASSWORD') WHERE user='YOURUSERNAME'"
and ofcourse change yourusername and yourpassword.
Posted: 07 Apr 2015 12:16
by alkarakiomar
Dear Dark83
Kindly note that i run that command but nothing change still i cannot access the web interface.( Checked the attached file error_2).
could you please advice me , what shall i do , and as i told you that i have the root password, but my problem only when that i cann't access the web interface. ( error_3)
waitting your advice.
Thank you
Posted: 07 Apr 2015 12:53
by darky83
Are you sure your username is 'admin'?
You entered the username during the initial setup, so if you entered something else then you need to use that username instead of 'admin'.
(also you forgot the backticks (`) so the command you entered does not work.
First try to get a list of your users with the command:
This should output atleast 1 row that contains an username.
Posted: 08 Apr 2015 08:34
by alkarakiomar
Appreciate you support first of all.
but my friend i run the command so many times, and i got a new error ( check the attached file ).
i don't know what shall i do now,k because i fed up
Posted: 08 Apr 2015 09:05
Do this first
cat /etc/EFA-Config |grep SQL|grep MAILWATCHSQLPWD
You should get one line back that looks like this:
MAILWATCHSQLPWD:XXX...XXX
where XXX...XXX is your mysql password.
If you do, type in
mysql -umailwatch -pXXX...XXX mailscanner
it will succeed or fail.
if it fails, do this
cat /etc/EFA-Config |grep SQL|grep MYSQLROOTPWD
You should get back a line like
MYSQLROOTPWD:YYY....YYY
where YYY...YYY is your mysql root password.
if you do, type in
mysql -uroot -pYYY...YYY mailscanner
If either mysql command works and you are connected to the database, type in this
post those results
Warning: do not post your passwords. We only need the results of the final query, or the results from the mysql command if they both failed.
Posted: 08 Apr 2015 09:56
by darky83
Hi alkarakiomar
Try the methode pdwalker mentioned,
Looking at the screenshots you have some of the quotes wrong so it is not working the line should be:
Note after the -p it should be a backtick not a quote, same for the last one for mailscanner that is a backtick not a single quote
But try the way pdwalker mentioned, that way you don't have to use the longer command.
Posted: 08 Apr 2015 15:42
by alkarakiomar
Hi Dark83
hope you are fine and everything is under control not like me
Please find the attached file ( error_5
i follow all your steps but still it fail
Best regards,
Posted: 09 Apr 2015 06:33
by DaN
Because he wrotes
/usr/...
Posted: 09 Apr 2015 06:55
by darky83
Yup I see a whole lot of typing mistakes, make sure it is exactly as mentioned above.
Posted: 09 Apr 2015 07:57
yeah, until you get the commands typed in properly, it's hard to go forward.
use the commands as I've written them. It'll take a few more steps, but there are fewer changes to make a mistake.
Posted: 10 Apr 2019 17:45
by anti-spam
i have to change the administrator's password, did a try with the command below, but i always receive a error message :
[root@mx2 ~]# /usr/bin/mysql -u mailwatch -p`cat /etc/EFA-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "UPDATE users SET password = md5('my-new-password') WHERE user='adminefa'"
ERROR 1054 (42S22) at line 1: Unknown column 'user' in 'where clause'
Is there a other way to change this password ?
Best regards
Posted: 10 Apr 2019 18:24
the fieldname is
username and not
user
select username, password from mailscanner.users;
| username | password |
| titi | $some password |
| tata@testdomain | $another password |
Posted: 12 Apr 2019 12:39
by anti-spam
hi,
i'm sorry, but i'm not able to find how to change this password...
It's urgent, as we HAVE to change it a.s.a.p., as someone else have this password ...
Posted: 12 Apr 2019 22:59
show users and passwd's
mysql -u root -p`cat /etc/EFA-Config | grep MYSQLROOTPWD | sed 's/.*://'` mailscanner -e "Select username, password from users"
update password for username: adminefa
/usr/bin/mysql -u root -p`cat /etc/EFA-Config | grep MYSQLROOTPWD | sed 's/.*://'` mailscanner -e "UPDATE users SET password = PASSWORD('mysecretpassword') WHERE username ='adminefa'"
TIP.
If you login to mysql -> use mailscanner; -> the update query is much easier. By creating a .my.cnf in your root directory , you can even login without typing (or grepping) passwords.
Posted: 14 Apr 2019 09:59
by anti-spam
i did a try with
and now i'm haning with : Bad Username or Password
The password is changed, because the show command show me a other and shorter crypted password ...
Is there a other way, to reset it to the original password ?
Posted: 14 Apr 2019 11:08
did the test, to be sure.
Create user
tempadm with password
dirkjan
/usr/bin/mysql -u mailwatch -p`cat /etc/EFA-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "INSERT INTO users SET username = 'tempadm', password = MD5('<dirkjan>'), fullname = 'tempadm', type ='A'"
Check if user is created ( and show the md5 pwd for 'dirkjan' )
mysql -u root -p`cat /etc/EFA-Config | grep MYSQLROOTPWD | sed 's/.*://'` mailscanner -e "Select username, password, MD5('dirkjan') as pwd from users"
To update a password for user tempadm
/usr/bin/mysql -u mailwatch -p`cat /etc/EFA-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "UPDATE users SET password = MD5('dirkjan') WHERE username = 'tempadm'"
After the first time login the password changes in the db.
Check to see the difference
Via Tools and link-> User Management you can change passwords (as user
dirkjan is not a secret anymore
Posted: 14 Apr 2019 11:45
by anti-spam
I was on that Tools and links, but i was to stupid to don't read the first line, User Managemant ...
I only did a search on "password" ....
I will have to learn to read more.
MANY thanks for your help.
Best regards
Posted: 18 Nov 2019 04:08
by DJ_L
Since this is the first hit from Google, updated path and table for 4.x - the MailWatch Settings -> Reset MailWatch Admin did not work for me, presumably due to invalid characters in the password - as best I can tell, I was unable to set a password that contained a single quote (') character but I was unable to grasp that from the error message, so I resorted to the direct method (below, or as per above).
To list users:
/usr/bin/mysql -u mailwatch -p`cat /etc/eFa/MailWatch-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "select * from users"
To change the password:
/usr/bin/mysql -u mailwatch -p`cat /etc/eFa/MailWatch-Config | grep MAILWATCHSQLPWD | sed 's/.*://'` mailscanner -e "UPDATE users SET password = md5('password') WHERE username='admin'"
HTH
