quarantine report not work
I installed EFA 3.0.2.3 on VMWARE that works excellently. Only I can not send quarantine reports to users. Users are load from the domain controller through ldap, all of them have triggered the flag for sending the report, but nobody receives it. If, as admin, I click on SEND NOW button I get the message "The quarantine report was successfully sent." but nothing is recived. If I click on SEND NOW button as user I recive message "An error occured while sending the quarantine report."
What could it be? Or Is there a log I can control to try to figure out what does not work?
Thank you
Thank you
Re: quarantine report not work
If you try running it from the shell, what do you see?
sudo /usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quaraninte_report.php
I don't have
/usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_quaraninte_report.php
but there is
run this one I read, for every users this warning message
=== Generating report for <user@remotedomain> type=U
==== Recipient e-mail address is <user@remotedomain>
==== Building list for <user@remotedomain>
==== Found 17 quarantined e-mails
PHP Notice: Use of undefined constant MAILWATCH_SMTP_HOSTNAME - assumed 'MAILWATCH_SMTP_HOSTNAME' in /var/www/html/mailscanner/functions.php on line 4459
==== ERROR sending e-mail to user@remotedomain Failed to add recipient: <user@remotedomain> [SMTP: Invalid response code received from server (code: 450, response: 4.1.8 <postmaster@acr.local>: Sender address rejected: Domain not found)]
==== Building list for <user@localdomain>
==== Found 0 quarantined e-mails
==== Building list for tutti@acr.local
==== Found 2 quarantined e-mails
but there is
PHP Notice is benign.
The problem is your remote SMTP server is rejecting the message on the basis that the sender address is an unknown domain. Might be as simple as a DNS or hosts entry on your destination server.
"postmaster@acr.local"
You can set this sender address as well in /var/www/html/mailscanner/conf.php
Yes, I changed sender email from localdomain to remotedomain in conf.php and now works!
Thank you very much for your help.
Bye
 Bye
I have a same problem, but I don't take error  when I execute the script /usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_report.php. The scritp output show me that no have e-mails on quarentine for the users, it's this not true! Many E-mails are let on quarentine and need that I release it manualy via mailwatch. What can to be happening? The Send Report stopped work after the update to version 3.0.2.3.
Are your users defined using email addresses and not usernames?
My users use the username only to log in to Mailwatch and the E-mail are specified in the Quarantine Report Recipient. After upgrading to the lastest version, the  Quarantine Report submission topped.
Mailwatch requires email addresses for usernames now for the quarantine reports to function properly.
"For all users other than Administrator you must use an email address for the username"
Bull's Eye!!!
The report was sent, but the error below is now happening.
This may be a misconfiguration in the SMTP host name. How do I configure this constant?
[root@efa01 .razor]# /usr/local/bin/mailwatch/tools/Cron_jobs/mailwatch_quarantine_report.php
=== Generating report for johndoe@mydomain.com type=U
==== Recipient e-mail address is johndoe@mydomain.com
==== Building list for johndoe@mydomain.com
==== Found 15 quarantined e-mails
Small bug, you can set that value if you want, but not necessary.  Will be fixed in next update.
Great! Solved! Thanks!
