Is it possible to have custom rules for a specific domain and not for all domains that have been setup?
Custom SA rule per domain
Re: Custom SA rule per domain
Probably.
What do you want to do exactly?
I want to create a custom rule that blocks any email where the header contains .rsvg.net, I can do this via the following SA rule.
header CONTAINS_RSGSV Received =~ /rsgsv\.net/i
score CONTAINS_RSGSV 10.0
describe CONTAINS_RSGSV rsgsv.net
What I want to do then is only have this rule be applied to email for domain.com and be ignored for all other domains.
Yes, simple enough. Off the top of my head, I forget the syntax, but if you peruse the existing rules in /var/lib/spamassassin/3.004001/updates_spamassassin_org you should be able to find an example of an "AND" rule that you can use as a template
Oh, shawniversion has just posted an example here: viewtopic.php?f=14&t=2416 that you could adapt to your needs.
