change mysql root password
enriluis
Post by enriluis »
hello all
I'm happy to use EFA! i need to change mysql root password, so i need to make another changes o modified configs to run fine??
Re: change mysql root password
If you change the mysql root password, you will have to update the root password listed in /etc/EFA-Config under MYSQLROOTPWD to avoid breaking things.
