AUGH! I cannot stand it.
When I am training the bayesian filter on multiple messages, the bloody UI will time out and log me out, which means, logging back in, finding my place, reselecting and retrying the operation with fewer messages.
Ultra @#$%@#! annoying!
Is there anyway we can make this security "feature" optional? I am capable of managing the security of my own systems and I'd rather have more convenience and this continually painful user experience.
ditch login timeouts?
Re: ditch login timeouts?
Are you on 3.0.2.2? 3.0.2.1 timeouts are definitely a problem.
yes, 3.0.2.2. it autoupdated overnight. and i still have all the same timeout errors and invalid access errors.
wait, it autoupdated, so my timeout x 10 changes would have reverted. let me add back and test again.
Did update this morning to 3.0.2.2 (from 3.0.2.1), and timeouts are gone.
No errors whatsoever. Will check for errors tomorrow again.
I also used to modify -a lot- and was sure to remember the changes done. Found that I modified more than I could remember
yeah, problem seems to have gone away in 3.0.2.2.
henk: depending on which files you modified, you should find a copy in the backup copy efa makes when upgrading. That's how I quickly recover my customizations (via vimdiff new old).
Sessions are completely reworked in 3.0.2.3. I think you'll like the enhancements.
sooooo much better now.
