I just upgraded EFA. After the upgrade everything seemed to be working again. However, after about ten minutes I was kicked out from Mailwatch and I am not able to log in anymore. I tried changing the password with the menu and webmin but I still can't login (Bad Username or Password).
I can see in webmin that the new password is format ****removed to protect privacy****
Any idea how I can get back into mailwatch?
Thanks,
Roger
