Hi guys,
I was looking if there is a way to disable Bounce for 550 5.1.1 which is "Recipient address" as it does not exist.
Currently EFA does that however my transport domains and relay servers has dkim configured which is not for EFA Postfix and hence emails bounced back goes to spam because of this.
Any suggestions to make EFA bounce for 550 5.1.1 from relay server its relaying to ?
Kind regards.
Configure Bounce from Relay server
Re: Configure Bounce from Relay server
bounce.
Do we have a answer to this?
Can you post a sanitized header from one of the messages being stopped in the SPAM filter?
I'm not sure what you mean about the DKIM not being for EFA causing messages to be blocked. Can you elaborate? Maybe diagram your mailflow and server setup so that it's easier to understand how you're set up?
I assume what he means is that his EFA doesn't sign outgoing emails with DKIm but lets hear what lecyberian says.
If that's the case, wouldn't a transport map withovizii wrote: 08 Mar 2017 21:53 I assume what he means is that his EFA doesn't sign outgoing emails with DKIm but lets hear what lecyberian says.
* smtp:fallback.relayhost.domain.com
