How To Build Script
derda
How To Build Script
Post by derda »
can someone please provide me with an updated URL for the build method? ( https://wiki.efa-project.org/doku.php?id=building_e.f.a )
The URL for the CentOS download is broken. Guess you've changed your forwarding on the website and broke the link :)
http://centos.mirrors.efa-project.org/6 ... inimal.iso
Thank you!
Regards
Re: How To Build Script
Yeah, I think darky83 is working on the mirrors. You can alternatively fetch a copy from any CentOS mirror for now.
derda
Post by derda »
Well, first of all thanks for your quick response.
Anyway. I am trying to install E.F.A using kickstart ( http://dl.efa-project.org/build/3.0.0.9/ks.cfg ) and this is crashing during install. Do you have any workaround for this issue?
You can find the screenshots for the issue here: http://imgur.com/a/iHmED
The latest kickstart you probably want is:
http://dl.efa-project.org/build/3.0.1.5/ks.cfg
Builds have been tested on 3.0.1.5, so give this one a shot. (I updated the wiki with this one) :)
However, we need the mirrors site fixed before you can proceed. I'll ping darky83 about this issue.
derda
Post by derda »
Thank you! Will you drop a note here once it's fixed?
darky83
Site Admin
Post by darky83 »
My bad, I enabled ipv6 on the centos mirrors page yesterday, and in Nginx you need a listen statement for both ipv4 and ipv6. forgot one :S
Should be working again.
derda
Post by derda »
Thank you - it's working as intended now.
