whitelist host
telvenes
whitelist host
Post by telvenes »
How can i whitelist this host?
Received Via:
109.247.116.8 asav21.altibox.net
109.247.144.79 79.109-247-144.customer.lyse.net
1.73 AWL Adjusted score from AWL reputation of From: address
0.25 GMD_PDF_EMPTY_BODY Attached PDF with empty message body
2.00 MIME_NO_TEXT No (properly identified) text body parts
1.40 MISSING_DATE Missing Date: header
0.14 MISSING_MID Missing Message-Id: header
-0.00 RCVD_IN_DNSWL_NONE Sender listed at http://www.dnswl.org/, no trust
Re: whitelist host
Is there a specific from address you can whitelist here?
telvenes
Re: whitelist host
Post by telvenes »
No. This is smtp for big internet company
telvenes
Re: whitelist host
Post by telvenes »
shawniverson wrote:Is there a specific from address you can whitelist here?
i have tried whitelist in efa but it does not work
Re: whitelist host
Yeah, that won't work on the header received via address.
You may want to perform a header check in postfix to bypass scanning altogether for this relay. If you do this, just bear in mind nothing will be logged.
/etc/postfix/header_checks:
/^Received Via: (.*)altibox.net$/ PASS
/^Received:/ HOLD
Then postmap the header_checks
sudo postmap /etc/postfix/header_checks
sudo service postfix restart
telvenes
Re: whitelist host
Post by telvenes »
there issnt another way? this should not be spam anyway. no other spamfilter blocks this?
telvenes
Re: whitelist host
Post by telvenes »
if I try adding sender whitelist it still comes as spam. why?
Re: whitelist host
I missed this post previously.
The first problem is that smtp provider is "spammy" and gets flagged for having lots of spam on its system. The second problem is their mail server doesn't seem "well configured" which is driving up the spam scores of messages coming from that isp. I've had similar problems with clients in China sending mail from the free email providers getting all their messages stopped cold as "high spam". Annoying and there is very little I can do about the ISPs reputation.
So, what do you do instead? If you know the addresses ahead of time coming from that isp, then you can add a negative spam score for those addresses/domains. Thus, if the ISP gets a score of +5 because they are assholes, then you can have spamassassin add a -5 score for someuser@somedomain.com who uses that isp, thus letting their mail come in.
Were you able to solve this problem in the end?
