"mxpf" [plugin]
"mxpf" [plugin]
Post by nicola.piazzi »
I wrote this simple plugin, mxpf
This plugin search B class of sender Ip Address and try to match B class of any Ip of mx records of declared domain
So when it match is very difficolut that sender is a spoofed domain, you can use MXPF_PASS to combine with other rules in addition to SPF_PASS
1) Unpack mxpf.cf and mxpf.pm under /etc/mail/spamassassin dir
2) put your score in mxpf.cf
mxpf.zip
(1.55 KiB) Downloaded 769 times
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
thanks, will test it. your default score was 0.20 - should the score not be negative? Just checking if I got this right: we want to give a bonus to emails where the sending IP is in the same b-class network as the MX, right?
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
one more question. the description reads:
# Mxpf helps to hit some non spoofed emails where the domain doesn't have SPF or DKIM
# It compare the B mask of sender ip with B mask of all mx records of domain
Does that mean this ONLY affects email domains without SPF or DKIM?
Re: "mxpf" [plugin]
NO, it is independent
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
Thanks, so only the description is misleading.
What about my other question:
Re: "mxpf" [plugin]
mistake, correct it please
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
nicola.piazzi wrote:NO, it is independent
How about checking if SPF and DKIM are correct first and only proceed with this test if they are not both correct. No point in awarding additional points if SPF and DKIM are already correct?
something along the lines of:
meta     __MXPF_PASS (eval:check_pf() && SPF_PASS && DKIM_VALID_AU)
Re: "mxpf" [plugin]
yes
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
this is what I made of mxpf.cf, testing now:
# It compares the B mask of sender ip with B mask of all mx records of domain
loadplugin      Mail::SpamAssassin::Plugin::mxpf mxpf.pm
header     __jacob_MXPF_PASS    eval:check_pf()
meta       _jacob_MXPF_PASS     (__jacob_MXPF_PASS && !SPF_PASS && !DKIM_VALID)
score      _jacob_MXPF_PASS     -0.50
describe   _jacob_MXPF_PASS     Sender IP has same B-Class IP as a MX Record of Sender Domain
Re: "mxpf" [plugin]
ovizii
Re: "mxpf" [plugin]
Post by ovizii »
@nicola: maybe you should submit the latest version which checks against a C-class network and not B-class?
Re: "mxpf" [plugin]
ovizil,
if you check the code, nicola left in a comment on how to match class C addresses. There are two places you'd need to change if you want to change it yourself.
Everyone,
Does anyone have any experience with debugging spamassassin modules? I'd like to debug a spamassassin module, but I have no idea how to get useful debug information out of the system.
Re: "mxpf" [plugin]
Found the answer. Invoke spamassassin from the command line against one of the messages in the message queues:
spamassassin -D -t < /var/spool/MailScanner/quarantine/[date]/spam/[messageid] 2>&1 | vim -
