Hi!
I just Updated to 3.0.1.0, and now I get an email every hoer with following message:
/etc/cron.hourly/mailwatch_relay.sh:
Notice: Constant SHOW_GREYLIST already defined in /var/www/html/mailscanner/conf.php on line 257
Do I need to be worried?
Regards
Philippe
[SOLVED] After Update to 3.0.1.0 hourly cron daemon mails
Re: After Update to 3.0.1.0 hourly cron daemon mails
the Constant "SHOW_GREYLIST" is duplicated in conf.php. Comment one out like
// define('SHOW_GREYLIST', true);
Jörg
Jörg
That seems to have fixed the Problem
- bikertrash
Re: [SOLVED] After Update to 3.0.1.0 hourly cron daemon mails
Excellent. Easy fix... thank you.
same problem here (/var/www/html/mailscanner/conf.php):
fix is in beta https://github.com/E-F-A/v3/blob/3da9fb ... 0.1.2-beta
// RPC port (defaults to 80 if not supplied)
// define('RPC_PORT', 80);
// RPC over SSL?? (defaults to port 443 unless RPC_PORT is supplied
// define('RPC_SSL', true);
// Greylisting menu item
// Define MailWatch logo name
define('MW_LOGO', 'mailwatch-logo.png');
// Define MailScanner logo name
define('MS_LOGO', 'mailscannerlogo.gif');
// Greylisting menu item <--------------
define('SHOW_GREYLIST', true); <--------------
