I'm not sure if this is expected - but I'm almost certainly seeing incomplete or partial daily spam reports from baruwa. In case it's not clear I mean the reports with subject "Baruwa quarantine report for ..."
I'm almost 100% sure I get hundreds or thousands of spams a day (thirty or so mailboxes, many with well published addresses that are over a decade old). Yet every single baruwa daily report contains exactly 25 messages. Am I missing some configuration parameter to change the report size? Is there a missing link to the full list?
Are baruwa reports complete?
Re: Are baruwa reports complete?
That should be allot more, my reports show hundreds ~ thousands of messages.
I have never seen any config variable for this in baruwa.
I will browse around in the mysql DB maybe there is some kind of option there.
How intriguing. Perhaps then it's config or status.
I imagine it's highly likely to be at least slightly misconfigured. Indeed - I just realised that dccifd has never been able to communicate with the world (port 6277 UDP). Maybe I should go back and check all the config too.
Edit: Ah, lots of missing outbound firewall ports now fixed ... but something perhaps is not quite right - the server cannot be "initialized" (Servers -> Scanners; stuck in the Initialize state, clicking the Initialize button does nothing). Could be false alarm, may not be, the status for the server is green at top of page.
That is ok, the servers -> Scanners is an unused page in baruwa 1.x
(http://lists.baruwa.org/pipermail/baruw ... 01788.html)
