Whitelist of Deny Filename
Hi all,
We have enabled Deny Filename = \.zip$ recently for safety reasons. How can we add few exceptions (or whitelist) in order to receive zip files from our customers?
Re: Whitelist of Deny Filename
You can create a ruleset in MailScanner.
If you need help or an example, let me know.
Thanks for reply, plesase kindly provide the syntax requirements and samples of ruleset.
1) Create new rule sets for the zip attachment
Example:
/etc/MailScanner/custom-deny-zips.conf
(items must be tab separated)
/etc/MailScanner/custom-allow-zips.conf
2) Create a new rule set for the domains to allow or deny
/etc/MailScanner/custom-ruleset-deny-filenames.conf
3) Add ruleset to MailScanner
Deny Filenames = %etc-dir%/custom-rulset-deny-filenames.conf
4) Restart MailScanner
Example:
deny \.zip$ Deny Zips
allow \.zip$ Allow Zips
Thank you so much.
If we have multiple allowed domains / email addresses, should we put them in separate line as below?
From: allow@allow.com %etc-dir%/custom-allow-zips.conf
Wow. That's easier than the way I went about it.
I realise you probably have nothing better to do
but some more how-tos like this would be so useful for those of us unfamiliar with the syntax for Mailscanner. Having said that, this one gives me some great hints on how to approach other tasks.
Thanks heaps Shawn.
Thanks heaps Shawn.
I tried the configurations but all zip files passed the EFA afterward
Then, I changed /etc/MainScanner/Mailscanner.conf as below
with /etc/MainScanner/custom-deny-zips.conf
Items are separated by TAB, but all zip attachments still pass EFA.
Do you have any idea?
Deny Filenames = %etc-dir%/custom-deny-zips.confCode: Select all
deny \.zip$ No Zips No ZipsDo you have any idea?
I used the above methodology successfully Tabootest. It is stating the bleeding obvious (which you sound like you are well beyond) but you did restart mailscanner after making the changes, didn't you?tabootest wrote:I tried the configurations but all zip files passed the EFA afterward
After made a change at config files, I restart the service by:
sudo service MailScanner restartRe: Whitelist of Deny Filename
Do all your edits pass a lint test okay?
Sorry, what is a lint test? how to recognize a lint test is ok?
if you go to "Tools/Links" you'll find the LINT tests for SpamAssassin and MailSacnner. They run basically through your configuration and ensure that there are no error essentially. They will display the output on the page that you can then go through and look for any errors and ensure your changes are valid.
I'm not sure why they're called a LINT test in here as LINT was a 'C' Program construct tester. I'm sure there's some logical reason, but I don't know it. Regardless, it is a good testing tool that has saved my bacon a few times with poorly written changes I have made, that it has found for me.
I'm not sure what "correct protocol" is, but i always do them after any changes to config.
Furthermore, how could I only block ZIP files whose size are smaller than 1MB while zipped files with size greater than 1MB are allowed.
