3.0.0.9 Postfix Queue Not Processing
irow
Post by irow »
After updating to 3.0.0.9 from 3.0.0.8, my Postfix queue is not processing inbound or outbound messages. Any suggestions?
Re: 3.0.0.9 Postfix Queue Not Processing
Rebooted, right?
irow
Post by irow »
Yes, rebooted a few times. I'm not seeing anything in particular in the logs.
Postfix running?
irow
Post by irow »
Which log files should I look at for this?
irow
Post by irow »
These are the log files from /var/log/maillog
Mar 22 21:09:06 EFA postfix/qmgr[1653]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:09:07 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 1653 exit status 1
Mar 22 21:09:07 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:09:21 EFA postfix/smtpd[2106]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:09:21 EFA postfix/smtpd[2106]: warning: database /etc/postfix/sender_access.db is older than source file /etc/postfix/sender_access
Mar 22 21:09:21 EFA postfix/smtpd[2106]: warning: hostname dynamic.vdc.vn does not resolve to address 113.162.185.60: Name or service not known
Mar 22 21:09:22 EFA postfix/trivial-rewrite[2109]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:10:07 EFA postfix/qmgr[2587]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:10:08 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 2587 exit status 1
Mar 22 21:10:08 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:11:08 EFA postfix/qmgr[2795]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:11:09 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 2795 exit status 1
Mar 22 21:11:09 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:11:25 EFA postfix/smtpd[2796]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:11:25 EFA postfix/smtpd[2796]: warning: database /etc/postfix/sender_access.db is older than source file /etc/postfix/sender_access
Mar 22 21:11:26 EFA postfix/smtpd[2797]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:11:26 EFA postfix/smtpd[2797]: warning: database /etc/postfix/sender_access.db is older than source file /etc/postfix/sender_access
Mar 22 21:11:26 EFA postfix/trivial-rewrite[2798]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:11:26 EFA postfix/cleanup[2799]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:12:09 EFA postfix/qmgr[2922]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:12:10 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 2922 exit status 1
Mar 22 21:12:10 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:13:10 EFA postfix/qmgr[3045]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:13:11 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 3045 exit status 1
Mar 22 21:13:11 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:14:11 EFA postfix/qmgr[3332]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:14:12 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 3332 exit status 1
Mar 22 21:14:12 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:15:12 EFA postfix/qmgr[4101]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:15:13 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 4101 exit status 1
Mar 22 21:15:13 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:16:13 EFA postfix/qmgr[4256]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:16:14 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 4256 exit status 1
Mar 22 21:16:14 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:16:39 EFA postfix/smtpd[4257]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:16:39 EFA postfix/smtpd[4257]: warning: database /etc/postfix/sender_access.db is older than source file /etc/postfix/sender_access
Mar 22 21:16:39 EFA postfix/smtpd[4257]: warning: hostname dsl-189-166-207-108-dyn.prod-infinitum.com.mx does not resolve to address 189.166.207.108: Name or service not known
Mar 22 21:16:39 EFA postfix/trivial-rewrite[4259]: warning: database /etc/postfix/virtual.db is older than source file /etc/postfix/virtual
Mar 22 21:17:14 EFA postfix/qmgr[4375]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:17:15 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 4375 exit status 1
Mar 22 21:17:15 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
Mar 22 21:18:15 EFA postfix/qmgr[4499]: fatal: parameter queue_run_delay: bad time value or unit: 180smeta_directory = /etc/postfix
Mar 22 21:18:16 EFA postfix/master[1651]: warning: process /usr/libexec/postfix/qmgr pid 4499 exit status 1
Mar 22 21:18:16 EFA postfix/master[1651]: warning: /usr/libexec/postfix/qmgr: bad command startup -- throttling
irow
Post by irow »
I solved this issue. Here's what happened:
The error in this log entry turned out to be the issue:
I edited the configuration file at: /etc/postfix/main.cf
I edited the line: queue_run_delay = 180smeta_directory = /etc/postfix
by dividing it into two lines:
I restarted postfix and the queue ran.
Log files can be wonderful, especially when they show you the errors.
