there is a problem sending daily reports to the users.
for a test a have create a user (username = mailaddress).
then i run the follow command to test it:
sudo /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.phpCode: Select all
PHP Strict Standards: Non-static method Mail::factory() should not be called statically in /usr/local/bin/mailwatch/tools/Cron_jobs/quarantine_report.php on line 382
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Mail/smtp.php on line 370
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 448
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 465
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 472
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 515
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 263
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 519
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Mail/smtp.php on line 251
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Mail/smtp.php on line 287
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 945
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 948
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 975
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 978
PHP Strict Standards: Non-static method PEAR::raiseError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 371
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 1266
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 1269
PHP Strict Standards: Non-static method PEAR::raiseError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Mail/smtp.php on line 304
==== Sent e-mail to XXX@XXX.XX
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 489
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 492
PHP Strict Standards: Non-static method PEAR::isError() should not be called statically, assuming $this from incompatible context in /var/www/html/mailscanner/lib/pear/Net/SMTP.php on line 495
