im using
Deny Filenames = \.zip$ in the Mailscanner.conf for blocking all zip files.
But is it possible to block all zip files except the files starting with (for example): ITR_*.zip?
Thank you
Zip file Block
Re: Zip file Block
That's a tough one.
You don't want to block basically "ITR_*\.zip$", so if you inverse that it with allow everything else (including zips).
So, you will need to use the rulesets instead.
How about this?
/etc/MailScanner/filename.rules.conf (use tabs between not spaces)
How about this?
allow ITR_*\.zip$ Allow zips with ITR Prefix Allow zips with ITR Prefix
#allow \.zip$ - -
deny \.zip$ Deny zips Deny zips
Re: Zip file Block
thank you for the answer.
Its now blocking the zip files with the new "Deny zips" message, but when sending it with prefix ITR_Test.zip its also blocked via the "Deny zips" rule.
Is the deny rule "higher" then the allow rule?
Got another idea?
Thank you!
Got another idea?
Thank you!
Re: Zip file Block
Dang, block overrides allow...
What about this?
What about this?
deny (?!ITR_)\.zip$ Deny zips Deny zips except for those with ITR prefix
Re: Zip file Block
mhm comes up with the new error message "Deny zips except for those with ITR prefix" but it is blocking files like "ITR_523.zip"
Thank you
Thank you
Re: Zip file Block
Forgot a wildcard...try this....
deny (?!ITR_).*\.zip$ Deny zips Deny zips except for those with ITR prefix
Re: Zip file Block
mhm the same "problem" it blocks all zip files
Thx
Thx
Re: Zip file Block
deny ^(?!ITR_).*\.zip$ Deny zips Deny zips except for those with ITR prefix
Re: Zip file Block
thank you very much, this is working
Thank you!
Thank you!
Re: Zip file Block
another question
is it possible to notify the sender AND the receiver that a zip was blocked? Also is there an option to just set *.zip to a score that it gets blocked and could be released via the Link that is sent from EFA3?
Thx
another question
Thx
