Initial WEb login - password not working?
lokdal
Post by lokdal »
Cant login, tried 3 different re-installs....what gives seriously?
darky83
Site Admin
Re: Initial WEb login - password not working?
Post by darky83 »
You have entered the username and the password during the initial setup yourself.
these user/pass combination should work just fine.
Don't make the mistake of using admin/root as the login account, you entered the username yourself during initial setup.
(see also https://efa-project.org/wiki/Initial_Configuration)
lokdal
Post by lokdal »
i have tried many different combinations. i have done it all myself i am 35 and have been an admin for years....something is wrong here and i cant figur eit out
Try the combination you used during the initial configuration.
