Extra Features
Justin
Extra Features
Post by Justin »
I have the following features which would be awesome if they were added.
1. In EFA-Config, a remove function for trusted domains (instead of only adding them)
2. Domain based whitelisting in Mailscanner
Re: Extra Features
1. Which function to which you are referring? There should be a delete option after you select the domain you want to edit?
2. You should already be able to do this. Example:
From: (leave first part blank) @ somedomain.sometld
To: default
