Mailgraph CPU
drewmorris
Mailgraph CPU
Post by drewmorris »
Hi... I noticed that on occasion I see mailgraph taking up a significant chunk of the CPU. If I don't use any of the graphing elements in EFA... can I turn it off? If so... where?
darky83
Site Admin
Re: Mailgraph CPU
Post by darky83 »
It should be just minimal, only on heavily used machine's you might see mailgraph use a lot of CPU cycles..
If you want to disable it:
service mailgraph stop
chkconfig mailgraph-init off
Ofcourse your graphs will stop working :)
