We were getting a lot of spam from .ninja and .science TLD's and on a google search I found some info on the URIBL site:
http://uribl.com/
April 6, 2015: New TLD Spam
If you are using SpamAssassin, and are currently receiving spam with new TLDs such as .LINK, .SCIENCE, .CRICKET, .NINJA, .XYZ, .CLICK (and others), it is because those URLs are not being checked against URIBL. In order to lookup these URLs, you will need to upgrade your RegistrarBoundaries.pm.
If you are running a recent version of SpamAssassin such as 3.3.2 or 3.4, simply download the RegistrarBoundaries.pm from SpamAssassin SVN and replace the one you currently have installed. Restart spamd (if you run it) for the change to take effect.
Link to SVN:
http://svn.apache.org/repos/asf/spamass ... ndaries.pm
I followed the instructions above and SA is now working a bit better.
New TLD Spam
