This does not work, as Postfix is still allowing SSLv2 and SSLv3. I am trying to get PCI compliance and scans are failing.
I have worked through several articles including this http://askubuntu.com/questions/537196/h ... -2014-3566 but when I run openssl s_client -connect mail.domainname.co.uk:25 –ssl3 or openssl s_client -connect mail.domainname.co.uk:25 -ssl2 from an external server, they both still show as connected. If I stop the Postfix service then the above does not connect.
I think the reason is that it is not using 'mandatory SSL' mode. I don't know how to change this.
Any help or guidance on this would be much appreciated.
Thanks for that additional information. When I saw CONNECTED I assumed it was still allowing connections. I am now seeing the following, could you confirm that this is what you would expect from the first two tests:
[root@mailprotect ~]# openssl s_client -starttls smtp -connect mail.domain.co.uk:25 -ssl2
CONNECTED(00000003)
write:errno=104
no peer certificate available
No client certificate CA names sent
SSL handshake has read 289 bytes and written 83 bytes
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : SSLv2
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
Krb5 Principal: None
PSK identity: None
PSK identity hint: None
Start Time: 1424171059
Timeout : 300 (sec)
Verify return code: 0 (ok)
[root@mailprotect ~]# openssl s_client -starttls smtp -connect mail.domain.co.uk:25 -ssl3
CONNECTED(00000003)
140329267877704:error:1409E0E5:SSL routines:SSL3_WRITE_BYTES:ssl handshake failure:s3_pkt.c:596:
SSL handshake has read 289 bytes and written 0 bytes
Compression: NONE
Expansion: NONE
SSL-Session:
Protocol : SSLv3
Cipher : 0000
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
PSK identity: None
Start Time: 1424171103
Timeout : 7200 (sec)
The third one is clearly connecting as it is showing certificate information.
1) Plug in your domain near the top
2) Send an email to check@ssl-tools.net from your efa or through your efa.
You may see a certificate issue if your EFA is using the default self-signed cert instead of a trusted cert, but you should get a green check mark on protocol if all is well. DANE will probably show as missing for most.
