I want to restore the backup file I created on another EFA virtal machine, and during the restore process I see this error message:
./backup/sql/backup.sql
ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: YES)
Both machines (source and target) were built from EFA 3.0.0.5 and have latest updates applied.
Has anybody an idea how to solve this?
Thanks,
Stefan
SQL error during restore
Re: SQL error during restore
Usually means you are using the wrong password on the target appliance...
I have used the same password during the setup dialog.
I also checked /etc/EFA-Config on both machines, I can see the same passwords there.
Thanks,
Stefan
Thanks,
Stefan
No two EFA Appliances should have the same password...also note that the SQL root password is not the same as the console root password.
thanks for your help and sorry for not expressing myself clearly enough.
This is what I want to achieve:
- Copy all settings and historical data from one EFA to another.
This is what I have done:
- Take a backup of the old one
- Newly installed a second EFA VM
- After finishing the initial setup dialog I copied the backup file to the disk of the new EFA
- Used EFA Menu via SSH to restore the backup (option 13)
- then I received that error message
Is this the correct process? I'm never asked for any password during the restore.
Thanks,
Stefan
Thanks,
Stefan
Oh, I follow you now
I've never had anyone try this as a migration tool before....
I intended it as a recovery mechanism for an single existing EFA...but now you have my gears turning.
The backup process does the following:
0) Perform a SQL dump
1) backup postfix configs
2) backup EFA-Config
3) Backup sysconfig
4) Backup parts of /etc
5) Backup Mailscanner config
6) Backup Cron jobs
7) Backup SQLGrey config
8) Backup SSH config
9) Backup PKI config/keys
10) Backup MailWatch config
11) Backup Apache config
The problem is that most of these backup items contain information specific and unique to the source EFA. If you run a restore on the same EFA, you are golden. Transferring this to another EFA results in a mess. In your case, the /etc/EFA-Config is overwritten on the destination appliance, and the wrong SQL password is automatically attempted.
So, I either need to as an enhancement 1) sanitize the backup for portability or 2) add a migration option that skips/merges configs with a destination appliance.
In the meantime, please take a look at this since it is applicable to your situation, instead of an ESVA to EFA it is an EFA to EFA...
viewtopic.php?f=14&t=513
3) Backup sysconfig
6) Backup Cron jobs
Thanks, I will try that!
In my specific case I see strange disk errors, probaby because of a faulty disk in my ESX - that's why I need to migrate to another machine.
Hi Shawn,
I understood, that a migration is not successful because the passwords in the backup EFA-Config dont match the passwords on the target machine. Every installation has its own randomly created passwords.
Is that correct?
Since data in EFA-Config seems to contain only machine individual parameters like ip settings a.s.o., what do you think about first insert the taget machine's EFA-Config into the backup-tarfile and then do the restore?
Cheers
akl
Is that correct?
Cheers
akl
