broken links (mailgraph & greylist)
azuercher
Post by azuercher »
I am configuring a testing EFA to replace an old Maia Mailguard install. I installing using the VMWare .ovf and did an update to the latest version (3.0.0.6) a couple days ago. It has been handleing mail inline with my old filter as I finsih setup. During this time I did access the Greylist section of the admin web interface. Today I spent alot of time today implementing LDAP logins and modified settings in config.php and functions.php. Now I noticed that when I goto the greylist I get a 404 error. Here is the message (Not Found The requested URL /mailscanner/sgwi/index.php was not found on this server.)
checking the location shows that my sgwi folder is at /var/www/html/sgwi not /var/www/html/mailscanner/sgwi. But I am unsure what was changed or how to fix this error?
Also mailgraph link shows this error (Not Found The requested URL /mailscanner/cgi-bin/mailgraph.cgi was not found on this server.)
How do I fix this?
Thanks,
Aaron
DaN
Re: broken links (mailgraph & greylist)
Post by DaN »
which files do you modify? Just the two, or do you have change any file in
/var/www/html
or
/etc/httpd
If not i would suggest to change the modification back part by part. Otherwise you could paste your changes. This would help others to help you.
azuercher
Post by azuercher »
I have only changed config.php and functions.php in the mailscanner directory per the instructions for the AD/LDAP user authentication thread.
So last night I did a reboot of my box and now those links are working again. I'm not sure what happened but glad its working. Thanks!
