Rejecting Invalid Users
mag
Post by mag »
Just started using EFA recently and all appears to be working well. I am planning on using this to replace an old, manually created mail filter.
The mail filter acts as a frontend to my postfix/imap server and one of the features I have is to reject invalid users. This is a setting in /etc/postfix/main.cf.
My question - can one modify the EFA files directly, namely add reject_unverified_recipient to the smtpd_recipient_restrictions line in the main.cf file?
If this file is created through the console/web configuration, how can one add this command to the postfix configuration?
Re: Rejecting Invalid Users
Yes.
It is not an auto generated file and is preserved during updates.
