installing EFA on a VPS
Hi All,
is it possible to install efa on a VPS where you have to to select a distro from a list f.i. leaseweb or Contabo.
what I'm looking for is a script to run after the default OS is installed...
I have been using Efa and ESVA for ages but allways on my VMWare servers and now I have to move to a VPS for the mailscanner to get the needed securety risk spreading
Re: installing EFA on a VPS
If you can install CentOS 6.6, then yes, you can install EFA on a VPS using the install efa without ks script on github.
thanks, can you give me some links for that?
okay got it installed but the config did not start, what is the command to configure?
nevermind
it's rebooting now and starting with the efa configure...
all working except the releasing of messages...
Software error:
Error in id syntax at /var/www/cgi-bin/release-msg.cgi line 105.
For help, please send mail to the webmaster (root@localhost), giving this error message and the time and date of the error.
Software error:
If you are satisfied that this message is not spam, you can release it from quarantine
by clicking http://efamailscanner.bikkernet.nl/cgi- ... 3287809f49
Darky,
This user may be post 3.0.0.6. Is there possibly a syntax error in the master branch for this line?
I Used the above named script
from github..
when "reporting as spam" from the URL in the mail is working fine...
