Bounceback to users when email blocked
Is it possible to get an email sent back to users when an email they send out is blocked for any reason i.e bad content / spam etc?
Re: Bounceback to users when email blocked
Why not just whitelist your internal server?
Can I ask this question again. In particular if I tick SMTP Client Restrictions > Reject clients with no reverse hostname
I didn't see the relevance to whitelisting your internal server.
If you enable that option, postfix will reject smtp client connections that don't have a valid reverse mapping. See here for an explanation
postfix will return a temporary error code of 450 (default settings) that tells the smtp client to retry later. If the smtp client is a valid smtp server, it should keep retrying until either it successfully delivers the message, or it gives up. If it gives up (sometimes after a couple of days), it should send a message to the sender, therefore there is nothing you need to do.
I suppose you could change the error to a 5xx series error which should notify the sender faster.
(someone please correct me if my understanding is incorrect)
