Obvious spam comes through
rolfkunst
Post by rolfkunst »
Hi everyone,
I have a question, i received 2 mails in the past two days which are obvious spam, but are coming throug the spamfilter and marked as clean. Only a score from 2. An RBL test on the IP address states that the IP is on a blacklist.
Do i have to tune the filter somehow?
I'd like to hear from you.
With regards,
Rolf Kunst
Re: Obvious spam comes through
Couple of things...
ImageCeberus skews the SA results by default...change it to 0
/etc/MailScanner/spam.assassin.prefs.conf
score ImageCeberus 0.00
Consider lowering your SA score threshold...
Required SpamAssassin Score = 3
b19wll
Post by b19wll »
Does the code below need to be added to that file?
or edited to reflect the 0.00 score?
Will
CODE: SELECT ALL
Just modify the existing entry.
mikemachin
Post by mikemachin »
I cant find this entry in the conf file
Looks since the latest ImageCeberus update this is no longer applicable. The scoring appears to be improved.
