Block .arj files with exe in
mikemachin
Post by mikemachin »
I have seen an increase in .arj files with a .exe file inside the archive - is there a way to block these or at least scan the exe for virus?
I haven't altered any settings as yet as am unsure what sections I need to be looking at
arenas
Re: Block .arj files with exe in
Post by arenas »
Check /etc/MailScanner/filename.rules.conf ... add
deny   \.arj$                  -       -
Then restart the service:
#service MailScanner restart
And I think that will do the trick.
mikemachin
Thanks - that worked a treat
