recently I migrated from eFa 4 to eFa 5 on a brand-new CentOS 9 stream machine. All went well, but now I see a strange behaviour.
Some E-mails (mostly from t-online.de) are delivered over and over again. On my Exchange 2019 box the mails are recognized as duplicates and don't appear in users mailboxes. Nevertheless the sender will get a "delayed delivery" notification and after some time an "undeliverable" message from his mailserver.
How could I find out what is causing this issue? I tried with "Debug = yes" in MailScanner.conf with no avail.
Regards
Mark
Periodic delivery of same incoming mail
Re: Periodic delivery of same incoming mail
https://telegra.ph/Muzhik-raspuskaet-06-25
https://telegra.ph/Burlan-biografiya-06-30
https://telegra.ph/6-poltorashek-07-08
https://telegra.ph/Pesenka-vlevo-07-13
https://telegra.ph/Ural-mkm-200-07-07
https://telegra.ph/Buket-iz-podsolnuhov-moskva-06-29
https://telegra.ph/Poluchit-pentin-1-06-28
https://telegra.ph/Razbor-slova-po-sost ... ovod-07-01
https://telegra.ph/Recept-lnyanoj-muki- ... niya-06-29
https://telegra.ph/Starinnyj-vodevil-kto-poet-07-05
https://telegra.ph/CHto-znachit-otpravi ... gram-07-07
https://telegra.ph/Kurs-pikolinata-hroma-07-14
https://telegra.ph/Sochi-torpedo-1609-24-07-09
https://telegra.ph/Pochemu-moet-dvigatel-06-28
https://telegra.ph/Stepyu-lazurnoyu-sre ... osti-06-25
https://telegra.ph/Mozhno-varit-kartosh ... cami-07-06
https://telegra.ph/Drom-shrv-07-14
https://telegra.ph/Oranzhevaya-korova-doroga-07-14
https://telegra.ph/Sajt-g-zadonsk-06-24
https://telegra.ph/Pril-i-prich-primery-07-01
https://telegra.ph/Polotencesushitel-su ... h500-06-27
https://telegra.ph/Mo-usovo-07-08
https://telegra.ph/buk-7-klass-starlight-str-7-07-05
https://telegra.ph/Sluzhba-ehkonomiches ... anie-06-29
https://telegra.ph/Sun-hotel-sharm-07-11
https://telegra.ph/Lorotoks-kapli-srok-godnosti-06-25
https://telegra.ph/Otdel-kadrov-bmk-07-12
https://telegra.ph/lebychevo-vyborg-avt ... dnya-07-14
https://telegra.ph/YA-missiya-chto-ehto-07-12
https://telegra.ph/Sleduyushchij-personazh-zzz-06-29
https://telegra.ph/Obshchaya-formula-go ... enov-06-27
https://telegra.ph/Vata-ili-penoplast-d ... niya-07-06
https://telegra.ph/Navesnaya-kachel-06-27
https://telegra.ph/Podrostok-hrapela-07-14
https://telegra.ph/spluatacii-chto-ehto-07-11
https://telegra.ph/Sshit-kukol-dlya-teatra-06-29
https://telegra.ph/CHto-takoe-ehlektronnyj-uchet-07-03
https://telegra.ph/Stolnyj-07-15
https://telegra.ph/Paracels-dovatora-07-01
https://telegra.ph/S-medovym-spasom-kar ... hnye-07-13
https://telegra.ph/Plity-perekrytiya-zh ... dcev-07-02
https://telegra.ph/Kogda-nachinaetsya-i ... opad-06-28
https://telegra.ph/Menedzher-plejs-07-14
https://telegra.ph/Matematika-6-nomer-84-str-17-07-13
https://telegra.ph/Telefon-dmitrovskogo ... sbyt-07-08
https://telegra.ph/Stahanovskaya-33-07-02
https://telegra.ph/Pensiya-v-aprele-sko ... tsya-07-03
https://telegra.ph/Kvartira-v-minske-ur ... srok-07-13
https://telegra.ph/SHkiv-na-19-val-06-28
https://telegra.ph/Svobodnaya-dlinnaya- ... asom-07-14
<a href="https://home-babos.ru">https://home-babos.ru</a>
https://telegra.ph/Total-sh-2-07-05
https://telegra.ph/Ogurcy-dlya-teplicy- ... unta-07-08
https://telegra.ph/agazina-dommarket-07-11
https://telegra.ph/Nekst-celnometallich ... ovoj-07-01
https://telegra.ph/Polozhenie-shkolnyj- ... 2025-06-28
https://telegra.ph/Vdol-truby-kran-06-26
https://telegra.ph/V-kinoteatre-za-den- ... etov-07-08
https://telegra.ph/Fonbet-rezultaty-fut ... dnya-06-25
https://telegra.ph/Polusapozhki-zhenski ... rogo-06-27
https://telegra.ph/Alfa-otel-betta-07-11
https://telegra.ph/Sochinenie-hram-svya ... riya-07-15
https://telegra.ph/Magicar-zzz-06-29
https://telegra.ph/Kitajskij-slozhnyj-ili-net-06-26
https://telegra.ph/If-is-she-smiling-07-04
https://telegra.ph/CHereda-kakaya-trava-06-25
https://telegra.ph/Zachem-vy-brosili-me ... esni-06-25
https://telegra.ph/Voenno-inzhenernaya- ... heva-07-06
https://telegra.ph/Vklyuchi-my-ubegaem-06-25
https://telegra.ph/Lodka-pvh-na-avito-n ... last-06-27
https://telegra.ph/Cerezit-st17-5l-07-13
https://telegra.ph/Hokkeisty-torosa-07-12
https://telegra.ph/Zakon-o-vruchenii-06-26
https://telegra.ph/Pastushya-sobaka-kak ... obak-06-25
https://telegra.ph/Remstroj-spb-07-12
https://telegra.ph/Pereskaz-kogda-carev ... -pir-07-02
https://telegra.ph/Futbol-atletiko-nasonal-07-08
https://telegra.ph/Procedures-in-sql-07-04
https://telegra.ph/Vtoroe-svojstvo-para ... lass-07-13
https://telegra.ph/Terafleks-otzyvy-pri-artroze-07-13
https://telegra.ph/Kvartiry-v-balakovo- ... onah-07-07
https://telegra.ph/Primery-na-slozhenie ... do-3-06-28
https://telegra.ph/Rabota-elec-domu-07-07
https://telegra.ph/Pesnya-sluchajnaya-n ... azov-07-08
https://telegra.ph/Main-leaf-06-27
https://telegra.ph/Dlinnye-shuby-pol-06-26
https://telegra.ph/Material-turan-chto-ehto-07-11-2
https://telegra.ph/Porcha-za-upokoj-07-05
https://telegra.ph/Kak-ustanovit-telegr ... stol-07-01
https://telegra.ph/Vremya-pereklyucheni ... reyu-07-03
https://telegra.ph/CHerchenie-marhi-ehk ... nnye-07-12
https://telegra.ph/Switch-split-pad-06-30
https://telegra.ph/Windows-10-iot-chto-ehto-07-14
https://telegra.ph/Luchshij-indeksnyj-fond-06-26
https://telegra.ph/Kiberneticheskogo-po ... essu-07-07
https://telegra.ph/Kolyuchij-chaj-07-14
https://telegra.ph/2-mosfilmovskij-pere ... tavy-07-08
https://telegra.ph/Kvadrocikly-sf-moto- ... vito-07-06
https://telegra.ph/Uznavat-naschet-raboty-06-25
https://telegra.ph/X-coupe-06-30
https://telegra.ph/2-pts-4-5-s-06-28
