V5 - 16) DKIM and DMARC
zane93
Post by zane93 »
What exactly does this option do "16) DKIM and DMARC"?
If it does not generate opendkim keys for all domains does a guide exist for v5? I looked at the various post was not sure if they still apply.
Re: V5 - 16) DKIM and DMARC
This option enables validation via opendkim and opendmarc. Enabling signing for opendkim requires additional setup.
Setup should be the same as in previous versions, so those posts should still apply.
thsobota
Post by thsobota »
Which is the best "previous post" to use?
_M_P
Post by _M_P »
this:
viewtopic.php?p=20158#p20158
I've succesfully implemented that feature on eFav5...
