What exactly does this option do "16) DKIM and DMARC"?
If it does not generate opendkim keys for all domains does a guide exist for v5? I looked at the various post was not sure if they still apply.
V5 - 16) DKIM and DMARC
Re: V5 - 16) DKIM and DMARC
This option enables validation via opendkim and opendmarc. Enabling signing for opendkim requires additional setup.
Setup should be the same as in previous versions, so those posts should still apply.
Which is the best "previous post" to use?
ngocnhungplaza
That option enables DKIM signing and DMARC handling within EFA, but it doesn't automatically generate OpenDKIM keys for all your domains. You'll still need to manually generate the keys and publish the DNS records. Some of the older guides still apply in principle, but there have been changes in V5, so it's best to double-check each step with the current setup. I’d recommend testing with a single domain first to make sure everything signs correctly.
Hello I'm NgocNhung.
