EVA config script is not starteing after reboot
Hi all just tried to install efa on a new VPS Rocky 9.4
I used this:
One-Step Install
eFa5 can be installed with just a single command, make sure you are logged in as root and you have a clean minimal installation to start with. Then just run the following command:
curl -sSL https://install.efa-project.org | bash
when the command has completed it asks for a reboot and then the config script does not pop up?
where can I find the config script? eFa first-time configure
I used this:
One-Step Install
Re: EVA config script is not starteing after reboot
Did you get an error during the install? It sounds like it did not install correctly.
no no error it is just completing the above script and asks for a reboot and the the configure screen does not presents itself, when i rerun the script it's saying that all packages are allready downloaded
Can you attach the file /var/log/eFa/build.log ?
Can you confirm that eFa is installed?
rpm -qa | grep eFa
root@localhost ~]# rpm -qa | grep eFa
[root@localhost ~]#
no response just blank line
[root@localhost ~]#
Hi there,
I have the same issue, but what I did notice, that on install there was a GPG "issue"
-----snip----
(285/285): re2c-2.2-1.el9.x86_64.rpm 4.7 MB/s | 497 kB 00:00
Total 7.3 MB/s | 103 MB 00:14
Extra Packages for Enterprise Linux 9 - x86_64 1.6 MB/s | 1.6 kB 00:00
Importing GPG key 0x3228467C:
Userid : "Fedora (epel9) <epel@fedoraproject.org>"
Fingerprint: FF8A D134 4597 106E CE81 3B91 8A38 72BF 3228 467C
Key imported successfully
Public key for MailScanner-5.5.1-5.eFa.el9.noarch.rpm is not installed
Public key for MailWatch-1.2.23-2.eFa.el9.noarch.rpm is not installed
Public key for clamav-unofficial-sigs-7.2.5.1-1.eFa.el9.noarch.rpm is not instal led
-----snip----
In other words either not all orthe wrong GPG Key seems to have been installed in the script....
Any thoughts?
-----snip----
-----snip----
Any thoughts?
Total 15 MB/s | 91 MB 00:06
Public key for clamav-unofficial-sigs-7.2.5.1-1.eFa.el9.noarch.rpm is not installed
Public key for dcc-2.3.168-1.eFa.el9.x86_64.rpm is not installed
Public key for eFa-5.0.0-8.eFa.el9.noarch.rpm is not installed
Public key for eFa-base-5.0.0-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Encoding-FixLatin-1.04-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Geo-IP-1.51-1.eFa.el9.noarch.rpm is not installed
Public key for perl-IP-Country-2.28-1.eFa.el9.noarch.rpm is not installed
Public key for perl-IP-Country-DB_File-3.03-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Mail-DMARC-1.20230215-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Net-DNS-Resolver-Programmable-0.009-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Net-IDN-Encode-2.500-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Net-LibIDN-0.12-1.eFa.el9.x86_64.rpm is not installed
Public key for perl-Sendmail-PMilter-1.24-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Sys-Hostname-Long-1.5-1.eFa.el9.noarch.rpm is not installed
Public key for perl-Test-File-ShareDir-1.001002-1.eFa.el9.noarch.rpm is not installed
Public key for postfix-3.5.23-1.eFa.el9.x86_64.rpm is not installed
Public key for spamassassin-4.0.1-2.eFa.el9.x86_64.rpm is not installed
Public key for sqlgrey-1.8.0-8.eFa.el9.noarch.rpm is not installed
Public key for sqlgreywebinterface-1.1.9-5.eFa.el9.noarch.rpm is not installed
Public key for tnef-1.4.18-1.eFa.el9.x86_64.rpm is not installed
Public key for unrar-6.2.5-1.eFa.el9.x86_64.rpm is not installed
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: GPG check FAILED
same as the user above error on the pub key
Try running this:ZimboKraut wrote: 27 Jun 2024 10:14
Any thoughts?
curl -sSL https://dl.efa-project.org/rpm/eFa5/centos9/RPM-GPG-KEY-eFa-Project-256 > RPM-GPG-KEY-eFa-Project-256
sudo rpm --import RPM-GPG-KEY-eFa-Project-256
sudo dnf install eFa
no more errors
spamassassin-4.0.1-2.eFa.el9.x86_64 sqlgrey-1:1.8.0-8.eFa.el9.noarch
sqlgreywebinterface-1:1.1.9-5.eFa.el9.noarch sscg-3.0.0-7.el9.x86_64
tmpwatch-2.11-20.el9.x86_64 tnef-1:1.4.18-1.eFa.el9.x86_64
unbound-1.16.2-3.el9_3.5.x86_64 unbound-libs-1.16.2-3.el9_3.5.x86_64
unrar-6.2.5-1.eFa.el9.x86_64 xml-common-0.6.3-58.el9.noarch
Complete!
[root@localhost ~]#
Complete!
[root@localhost ~]#
Reboot and you should be good.
ran the script looks oke for now
will keep on configuring..
thanks for the help
thanks for the help
