Cannot find configuration value: incoming queue dir in
fatih.gokdogan
Post by fatih.gokdogan »
I get the following error
Re: Cannot find configuration value: incoming queue dir in
That is rather bizarre. That setting appears to be missing from your config?
That parameter does not exist in the mailscanner.conf
what did you change in your system between the time the error showed up in your web interface and before when it did not?
Oh, I see how the function works.
Do you have the following option in your /etc/MailScanner/MailScanner.conf file?
Incoming Queue Dir = /var/spool/MailScanner/milterin
What are the file permissions on /etc/MailScanner and /etc/MailScanner/MailScanner.conf?
[root@efa4 mailscanner]# ls -ld /etc/MailScanner/ /etc/MailScanner/MailScanner.conf
drwxr-xr-x. 5 root root   4096 Apr 13 20:00 /etc/MailScanner/
-rw-r--r--  1 root root 154210 Mar 17 16:58 /etc/MailScanner/MailScanner.conf
fatih.gokdogan
I didn't change anything.
available in conf extension
change
MTA = msmail
to
MTA = sendmail
if i do sendmail it works fine
fatih.gokdogan
drwxr-xr-x. 5 root root 4096 Nis 13 08:58 /etc/MailScanner/
-rw-r--r--. 1 root root 154123 Nis 13 11:58 /etc/MailScanner/MailScanner.conf
freyuh
Post by freyuh »
Maybe file system full?
fatih.gokdogan
freyuh wrote: 13 Apr 2022 12:14 Maybe file system full?
no it's not full
freyuh
Post by freyuh »
And enough free inodes?
freyuh
Post by freyuh »
What about the mem/swap usage?
freyuh
Post by freyuh »
This seems to be OK ... hm ... have to think about it a little more ...
freyuh
Post by freyuh »
Are there any errors in /var/log/maillog or /var/log/messages?
fatih.gokdogan
freyuh wrote: 13 Apr 2022 14:28 Are there any errors in /var/log/maillog or /var/log/messages?
no errors
freyuh
Post by freyuh »
Anything in the error logs under /var/log/httpd and /var/log/php-fpm?
Tried to restart the webserver?
fatih.gokdogan
freyuh wrote: 13 Apr 2022 15:31 Anything in the error logs under /var/log/httpd and /var/log/php-fpm?
there is only this error :think:
[13-Apr-2022 18:06:43 Europe/Istanbul] PHP Warning: Directory /var/www/html/mailscanner/lib/htmlpurifier/standalone/HTMLPurifier/DefinitionCache/Serializer not writable, please chmod to 777 in /var/www/html/mailscanner/lib/htmlpurifier$
freyuh
Post by freyuh »
I also had this error and changed the permissions as displayed.
But this error didn't lead to any errors on my installations.
Restarting the webserver doesn't change anything/resolve the error?
fatih.gokdogan
freyuh wrote: 13 Apr 2022 16:01 I also had this error and changed the permissions as displayed.
I restarted the machine, It didn't happen
freyuh
Post by freyuh »
Have you changed anything in the MailScanner.conf and afterwards the error appeared?
If so, maybe you typed a special character which is not displayed but interpreted by the php script.
fatih.gokdogan
freyuh wrote: 13 Apr 2022 16:56 Have you changed anything in the MailScanner.conf and afterwards the error appeared?
I didn't make any changes
I installed the script for the first time
freyuh
Post by freyuh »
Can you tell me which system (ISO) you used. So I can install it on my own and test it.
Which language did you use for installation?
fatih.gokdogan
freyuh wrote: 13 Apr 2022 17:13 Can you tell me which system (ISO) you used. So I can install it on my own and test it.
CentOS-7-x86_64-Minimal-2003.iso
Language : TR
Weird. I have no idea. I have a stock centos 7.0 installation with the latest v4.x version of eFa. My MTA is set to "msmail", so I have no idea what is different between your system and mine and what is causing the difference.
Clearly something is wrong.
fatih.gokdogan
pdwalker wrote: 14 Apr 2022 06:05 Weird. I have no idea. I have a stock centos 7.0 installation with the latest v4.x version of eFa. My MTA is set to "msmail", so I have no idea what is different between your system and mine and what is causing the difference.
definitely a strange situation, I installed centos 8, it still didn't change :think:
freyuh
Post by freyuh »
Is it possible for you, to install an english system and test it?
Maybe it's a problem with the turkish language.
